Hello folks!
I tried to use the Logic 2 beta on an Ubuntu 20.04 based machine with the KDE desktop environment with a dual screen setup.
Every time I start it I have to toggle the maximized screen mode on and off to get it aligned with my screens:
The old version was started properly in maximized mode all the time (until it got disabled )
rani
August 12, 2020, 3:46pm
#2
First of all, thanks for letting us know!
Does it happen only when you have two monitors? Can you please try it out with a single monitor? We’ll also try to reproduce it on our end
The old version (1.2.29) was not disabled, there is a bug there that you can override (sorry about that). Please see the discussion below:
Sorry for the trouble everyone! When we started re-investing in the Logic 1.x software and started releasing the beta versions, we got really fired up about regularly releasing new versions of the application. One of the things we talked about internally (but never decided if we wanted to use) was to add a system that would allow us to later disable versions of the app, so that we could slowly push people into the latest versions of the software.
The system was never actually used (it’s control…
Hello Rani!
Yes it is the same when a single monitor is used:
I have an another box where I ran the same OS/DE but the monitors are not having different resolution and the issue occurs there as well.
