Measurements - you can now select a region (Shift + drag) and get basic measurements for that range. This is a basic version and a lot of features are coming soon, such as Python support and data tooltips
Better memory management and adjustable buffer size
Store and reload analyzers when re-opening the app
Scroll up/down over the graphs using alt/option key + scroll
Jump to next/previous digital transition
Improved serial terminal - analyzer results now match to analyzer color
Process back-logged data when stopping a capture
App stability improvements and bug fixes
Coming next
Python measurements
High-level Python analyzers
Improved live view
Decoded protocols table
rani
made this a banner . It will appear at the top of every page until it is dismissed by the user.
#2
Just tried the OSX version and it just comes up with a blank black window. Tried doing a refresh and shows saleae … then clears and goes black. No options, settings or widows in the main black window.
I tried the Linux Logic-2.2.2-master.AppImage on an up-to-date x64 Ubuntu 18.04 and am getting a black screen. I remove ~/.config/Logic : no change. Also tried env LIBGL_ALWAYS_SOFTWARE=1, which fixes a black screen problem on Eagle, and it didn’t help either.
After a capture is complete, I was scrolling and zooming in and all of the traces and analyzer bubbles all disappeared. Nothing I tried brought them back. The GUI did not crash because I could start a new capture OK. I could see the scroll bar on the bottom moving as I zoomed in and out with no traces. I’ve seen this happen a couple of times.
The screen shot shows a part of an orange bubble is still there in the lower left if that is a clue. I had two analyzers active and had the cursor on the trace for the bottom channel when I was zooming.
