Logic2 & Pro 8 > connection problems
Good morning,
I’ve had a Pro 8 for a few days now. Unfortunately, I have the problem that the device is not automatically recognized by the Logic 2 software after a restart. I can’t update USB3 drivers because the system says the latest ones are available. Now I have to unplug the device and plug it back in every time so that it is recognized. the usb socket is happy…
is there any other workaround?
Can you share operating system, version, computer model, etc?
thank you for the fast response!
i hope its all what you need.
JAN.txt (107.2 KB)
I haven’t seen this before…
First thing to try is try and isolate it to the port or the cable:
  • Try another cable
  • Can you try a different USB port (front vs back on a Desktop)
  • Bypass any USB hub that you might be using and plug in directly
Have you customized any BIOS settings related to USB selective suspend, XHCI/EHCI Hand-Off, USB power management, or BIOS fast startup?
i dont use a hub.
the adapter works with the original cable.
and i dont have change bios settings…
I’ve had similar issues on laptops and some USB devices. This may not, be your problem, but, USB ports now have interesting charging capabilities, allowing power to the device, even after the PC has shut down.
Having a USB device powered even after the PC has turned off might confuse the internal state machine of the device, I might not realize that it was disconnected and then reconnected.
I just looked around to see if I can find a solution on line, and found another couple of problems. I know I recently added a Dell that had these issues with a PEMIcro USB/BDM dongle. I fixed it before I used my Saleae, so I can’t say it’s the same issue.
https://www.dell.com/community/en/conversations/xps/usb-power-on-xps-17-how-to-turn-off-when-computer-turns-off/647fa33bf4ccf8a8de90b691
https://answers.microsoft.com/en-us/windows/forum/all/powering-off-usb-ports-during-shutdown-sleep-mode/6356091e-4834-45b3-a8dc-2f608671d1f5
My search term in google was “dell laptop disable USB charging while PC is off”. Try windows, or you PC manufacturer instead of Dell. I see several different naming schemes for the “legacy” or “power suspend” option, and all seem to point to BIOS, but I am sure I fixed it in Windows.
Good hunting.
My computer is always completely unplugged, i.e. there is no voltage at the LA. If I switch the computer to standby and then start it up again, it is recognized immediately…
It must be a driver problem or something to do with the Logic software.
In that case, I’m out of ideas, and all I can do is wish you all your best in your hunt for a solution.
When you say ‘restart’ do you mean:
  • rebooting the PC?
  • shutdown/turn off and power-up the PC?
  • sleep/hibernate and wake-up the PC?
  • exit/restarting the Logic 2 software with the hardware device still plugged in?
  • something else?
I believe when a logic device is first plugged in, it is in a special boot mode waiting for the firmware over USB. I know I’ve had to unplug/replug in the hardware sometimes to get things to work.
As others have stated, modern PCs may not power cycle the USB port after rebooting or even while sleeping to provide charging power while the PC is ‘off’ … but this feature may only be on certain USB ports, so plugging into a different port can help. Likewise, I’ve had problems in the past that were resolved with a new USB cable, as the old one would intermittently lose the USB connection and confuse the software/connected device state until I unplugged it and/or restarted the Logic 2 application. Once I replaced the cable, the issue was resolved.
So, did you try a different USB port or a different cable?
