Logic 2.3.4
Windows - Linux - MacOS
What’s New
  • Reset channel names via the right-click menu
  • Show a tooltip with the channel name when hovering over the channel number
  • Added ellipsis and a tooltip to long analyzer settings names
  • Drop incoming triggers after stopping a capture
  • Better handling of WebGL errors
  • Added support links for various errors
  • Consistent UI for all time inputs
  • Export dialog - Added a warning and a link to the docs
  • Switch to the table pane when jumping to a bubble
  • All dialogs now support closing via Esc
Bug fixes
  • Fixed timing display bar values
  • Use correct capture settings when switching and closing tabs
  • Possible fix for config storage package
  • Fixed terminal scroll handler
  • Fixed regression: Multi-bubble tooltip back
  • Fixed regression: Support mouse interaction below the channels region
  • Analyzer trigger error on setup
  • Ignore right-clicks when updating a measurement
  • Fix calculation of Python AnalogData times
Screenshots from 2.3.4
Silly question, does it support saving screenshot to a file?
No, we recommend using your OS built-in tool for that, e.g. Cmd+Shift+5 on Mac or WinKey+Shift+S on Windows.
If you prefer to use an in-app tool for screenshots we’d love to know why :slight_smile:
I still wish that there were less vertical “dead space” on each channel when they are made as short as possible. 90% of the time I need to maximize the vertical real estate on my screen, so I want as many channels as possible in as little vertical space as possible. I end up with this:
Which works, but visually there is a ton of empty space (vertically) and I’d much rather be have taller signal traces so that I can more easily see what’s a high and what’s a low. It’s just really hard to quickly parse what’s going on when the traces are so short.
I realize that all of that dead space is for the horizontal measurements that pop up as you move your cursor around - and those measurements ARE important. I just wish there were a way for the traces to normally take up the WHOLE vertical space of each channel, and then either shrink (just that channel) automatically if you need to see measurements, or have the measurements overlayed on the signals above and below the one being measured - something so that we can have more vertical ‘signal to deadspace’.
@Brian just to clarify - you want to keep the measurements around, right? Otherwise, you can turn them off and the dead space will disappear :slight_smile:
Ahh, I didn’t even realized I could do that! That will be a big help - I don’t see how to turn them off though. Where do I do that?
Still, they are very useful every now and then - it would be nice if the interface could adapt and only use up vertical space for measurements when it needed to and not all the time. :slight_smile:
Right click on the channels
Oh! I got it now. Thanks! That’s a global setting, right? So why wouldn’t it be in like a preferences menu somewhere? Seems like if I right click on a channel, that change should ONLY apply to the channel I right clicked on (i.e a local channel setting).
Just to be thorough, usually on linux you can press the PrntScr button on your keyboard and it takes a screenshot. Alt+PrntScr I believe captures just the active window. This works at least on Ubuntu derivatives.
I’m using capturing mode in Loop mode and stream the data to the terminal.
Application closed after two days operation. Now I recognized that on my test pc the harddisk is full.
I guess that the data is temporarily stored on hdd. But I do not find the location of the temp files .
thx
ok I found it. within AppData\temp I suppose it is named analyzer_db*
It seems that they are never cleaned up.
This is a development of a feed-back already listed as Q4.
Instead of displaying an error message when the selected
As T1 comes after T0, selecting T1 as start and T0 as end also results in an error.
I suggest to display only the markers strictly after the marker selected for start time, T1 only in the example below.
  • Q10a For end time if start time has been defined, list time and trigger markers strictly after the marker already selected for start time.
  • Q10b For start time if end time has been defined, list time and trigger markers strictly before the marker already selected for end time.
All questions Q1…Q7, Q8 and Q9 remain open for release 2.3.4.
Please add your ideas (or vote on it if it already exists) if you haven’t already on our ideas site: https://ideas.saleae.com/b/feature-requests/. Thanks for your feedback.
