Measurements
Hi
I’m using a Login Pro 8
I want to see on the screen several measurements like maximum and minimum voltage.
On Saleae I can only show time measurements.
Is this possible? How can I do it?
thanks
On the side panel below the start button there are four icons. The bottom icon (messed up grid of boxes) gives access to the Extensions panel. Scroll to the bottom of the list if extensions and you will find “Voltage min/max”. Click on the title to show a description including installation and usage instructions.
If you are familiar with Python or programming generally you can write your own measurement extensions and High Level Analyzers to add your own features.
@eduardo.av.goncalves Hopefully these support articles below will help as well!
Once you install the “Voltage Min and Max” extension, you can add the measurement per the below instructions:
