Hi all,
I am using Logic 2 to trace multiple digital and analog channels. (See screenshort for reference.)
For some of the digital channels we use high level analyzers.
For the analog channels I create analog measurement using Ctrl-G.
Currently I create the analog measurements manually using Ctrl-G but I would like to do this automated.
Either based on some threshold (i.e. >100 mV) or based on a digital channel (maybe with chopping ~5µsec on start and end of that pulse).
I did not find any extensions or built in options to do that.
Is there some mechanism available to support that?
Also, currently I can only check the results in that window on the right side of the GUI.
Is there some way to export these measurements into a CSV file?
Preferrably the export should go into same file as the exported data from some high level analyzers to properly align the measurements with decoded data.
Is there some support for that?
Best Regards
Gerhard
