Logic Socket API with Logic 2 software
Hi! I’d like to use a TCP connection to control the Logic 2 software as described in the “Logic Socket API Users Guide”, but can’t find the “Enable scripting socket server” box to check (only Automation one), is it still valid for Logic 2 software?
Thank you
@sicon76 The Socket API you are referring to is no longer supported and only works on our legacy Logic 1.x software.
For automation in our Logic 2 software, you’ll want to refer to our Automation API documentation below.
https://saleae.github.io/logic2-automation/
Additionally, you can refer to some example scripts and function use cases below.
I hope that helps!
