I have the following problems with HLAs in Logic 2.4.21.
Not honoring formatting from result_types in my HLA main class. This was working as expected in 2.4.14.
When reloading my HLA via Reload Source, status reports 0% and stays there. Reload seems to be working fine.
Still using Python 3.8.18 which is now officially unsupported and end-of-life. This will be an ongoing maintenance requirement to stay ahead of their published schedule.
@bcr Sorry for the trouble with that, and thanks for the feedback.
For the issue with not honoring formatting from result_types, can you share your HLA source code with us, along with an example capture file (in .sal file format) where we can immediately load your HLA and test this behavior on? If there are any LLA/HLA settings we should be aware of as well that would reproduce the issue, let us know. We would like to test this on 2.4.14 and 2.4.21.
We’ll test the “Reload Source” functionality using your provided HLA as well
As for updating Python, this is on our backlog, but unfortunately, we are not able to commit to working on it yet due to other priority projects. We’re tracking this below however, and I’ve added a comment for you to track your need for this as well.
