I know I can export raw data between timing markers, but what I’m after is the analysed data - which I can only seem to get from the analysers view - and I have to take it as text and for the entire capture or the visible window.
Is there any way to export the (analysed) data for a timing marker pair?
@remy You bring up a good point. Apologies for the limitations with our export options. I’ll bring this up with the team here.
One workaround would be to save a copy of your capture file, trim the capture file (instructions below), then export all the data in the newly trimmed capture. I understand this is pretty cumbersome, and we certainly could add a “export between timing markers” option, similar to the option we provide for exporting raw data.
In the meantime, can you give me an idea of what kind of data captures you are recording, and what you do with the trimmed down exported files?
Hi Tim, do you have an update on this feature being planned in a future Logic tool release? If not, do you have a tracker in Logic 2 - Ideas and Feature Requests - Saleae that I can +1 ?
@Marco_r Thanks for checking in on this! In case you are looking to quickly export decoded data from analyzers, or data from the Data Table, between specified timing markers, this is currently not possible.
The capability to export between timing markers is still possible when exporting raw data however.
It doesn’t looks like this has been posted on our ideas site yet either. Feel free to get that posted! Alternatively, I’d be happy to post it on your behalf as well if you’d like.
Thanks Tim for the reply. If you could post directly as a follow up to @remy ‘s initial query it would be great. Once you do, could you provide the link/reference so I can add it to my followed topics?
