Add timing marker to saved trace?
Is it possible to add timing markers to a trace that has been previously saved? I need to add more markers and information to an existing trace.
@bruce.p.clemens Yes, this is possible! There’s nothing extra you need to do. After opening your previously saved capture via our Logic 2 app, you can add timing markers to it via the normal methods described in the support article below:
Let me know if you run into any particular issues with that!
Thank you, timreyes.
At one point, I thought I was prevented from adding markers due to a message indicating the saved capture was locked. But - I can’t reproduce that failure any longer. I can add markers using the procedure you describe.
Regards,
Bruce
