- When trying to close protected captures or the application with protected captures you will be prompted to save the capture first.
- Removed cursor focus from the comment field for measurements so that you can easily remove a measure using the delete or backspace key.
- You can now resize the Timing Marker and Measurement sidebar sections to allocated more space for your given needs.
- Fixed issue where pressing the
Rkey would crash the app if the Export Raw Data dialog was open - Fixed issue where no channels were selected when opening the Export Raw Data dialog
