Check out the pre-release update to the Measurement API! - Read more about it in the release notes.
What’s New
- Marquee zoom is now available on analog channels. Use
Alt-Dragfor XY Range Zoom orCtrl-Drag Up/Downfor Y (Voltage) Range Zoom orCtrl-Drag Left/Rightfor X (Time) Range Zoom
- Fixed issue where extensions were unable to be published due to a mismatch with extension API versions
- Fixed issue where timing marker comment box would flash when active timing marker was clicked
- Fixed issue where Loading Existing Extensions and Save Raw Data paths were equivalent. They are now persisted separately.
- Fixed issue where the active tab was not in view in the bottom tab bar when many tabs were open or when dragging and dropping many capture files
- Improved rendering when resizing application window
- When Exiting the app while Exporting Raw Data or Saving a Capture is in progress a dialog will appear to confirm exit. This is to prevent data from being corrupted by exiting the app while saving to disk.
Up/DownandEnterkeys can be used in analyzer menu for selection
