Is there a way to combine two captures into separate channels in a single capture “file” so that you can easily compare them against the other? This would really help with debugging between two systems.
I tried opening up the capture files myself, but since they’re binary I couldn’t easily figure out how to do the combination.
All that should be required is a time delta input that allows shifting of the two waveforms compared to the other. Ideally that would be a part of the logic software, but if it’s a separate tool that would be fine as well.
Cheers,
