When checking DATA, I get framing errors, what cases this, and how do I get rid of them?
Camerart
Sorry about this. It’s likely that the incoming data pattern is not in a format that the analyzer you have set up recognizes. Can you attach a copy of your capture file? I’d be happy to review it for you.
@camerart A common issue is caused by glitches. More information on our glitch filter can be found below.
Hi T,
If glitches are not a real problem, but just look odd, then I’ll leave things as they are, although I will try the filter, and see what happens.
Thanks, Camerart.
P.S excellent and indispencable piece of equipment.
