First, thank you for the work on Logic 2. (and Logic 1 for that matter)
This has been an invaluable tool in my tool box. Love you guys!
Today, I am reversing a VFD controller that is rumored to use 9bit serial to communicate because there are multiple devices on this ‘bus’. The 9th bit is used to notify the device that this packet is an address packet. The rest of the communication to the device is supposed to be normal 8bit.
19,200 baud, I have the analyzer set to its lowest setting, assuming 1k samples a second is enough, perhaps not?
The message on the display is - “PLEASE WAIT…TESTING MEMORY.”
My capture is the following -
Source Type Time Duratio Data Error ASCII value Expected
FROM Machine data 8.84464 0.00048 0x02 Start of Text
FROM Machine data 8.84524 0.00048 0x70 framing p
FROM Machine data 8.8458 0.00048 0x22 framing "
FROM Machine data 8.84636 0.00048 0x00 framing
FROM Machine data 8.84696 0.00048 0x00 framing
FROM Machine data 8.84752 0.00048 0x00 framing
FROM Machine data 8.84808 0.00048 0x02 framing Start of Text
FROM Machine data 8.84868 0.00048 0x3F framing ?
FROM Machine data 8.84924 0.00048 0x0E framing Shift Out
FROM Machine data 8.8498 0.00048 0x10 framing data link escape
FROM Machine data 8.8504 0.00048 0x04 framing end of transmission
FROM Machine data 8.85096 0.00048 0x50 framing ( P
FROM Machine data 8.85152 0.00048 0x08 framing backspace L
FROM Machine data 8.85212 0.00048 0x45 framing E E
FROM Machine data 8.85268 0.00048 0x40 framing @ A
FROM Machine data 8.85324 0.00048 0x12 framing device ctrl 2 S
FROM Machine data 8.85384 0.00048 0x45 framing E E
FROM Machine data 8.8544 0.00048 0x20 framing space
FROM Machine data 8.85496 0.00048 0x1E framing record separator W
FROM Machine data 8.85556 0.00048 0x41 framing A A
FROM Machine data 8.85612 0.00048 0x48 framing H I
FROM Machine data 8.85668 0.00048 0x1C framing file seperator T
FROM Machine data 8.85728 0.00048 0x2E framing . .
FROM Machine data 8.85784 0.00048 0x2E framing . .
FROM Machine data 8.8584 0.00048 0x2E framing . .
FROM Machine data 8.859 0.00048 0x44 framing D T
FROM Machine data 8.85956 0.00048 0x45 framing E E
FROM Machine data 8.86012 0.00048 0x12 framing device ctrl 2 S
FROM Machine data 8.86072 0.00048 0x44 framing D T
FROM Machine data 8.86128 0.00048 0x49 framing I I
FROM Machine data 8.86184 0.00048 0x0E framing Shift Out N
FROM Machine data 8.86244 0.00048 0x47 framing apostrophe G
FROM Machine data 8.863 0.00048 0x20 framing data link escape space
FROM Machine data 8.86356 0.00048 0x0C framing form feed M
FROM Machine data 8.86416 0.00048 0x45 framing - E
FROM Machine data 8.86472 0.00048 0x4D framing M M
FROM Machine data 8.86528 0.00048 0x0E framing Shift Out O
FROM Machine data 8.86588 0.00048 0x40 framing @ R
FROM Machine data 8.86644 0.00048 0x59 framing Y Y
FROM Machine data 8.867 0.00048 0x2E framing . .
FROM Machine data 8.8676 0.00048 0x49 framing I
FROM Machine data 8.86816 0.00048 0x93 framing
I hope that pasted OK. The last column is what should have been captured…
Odd how some are OK and others are not.
Is this something Glitch Filter will clean up?
Or is this 9bit serial screwing something up? Note, when I change the analyzer to 9bit it doesn’t look any better… heh
I will try again tonight with Glitch Filter turned on, also go back to Logic 1 and see if it is the same.
It isn’t ‘line noise’… I feel if it was, the packets would be much longer. I think it is the third byte in the packet that tells the length of the message. It always matches. Line noise would screw that up.
