MSO raw extraction other function limitation
Hi
I used previous saleae Pro 2.
Now I buyed the new MSO.
but “Delete Data(befor/after/off screen” is not supported.
  "Export Raw Data" Time Range is not supported for Timiming Markers(ony "All time" and Visible Screen")
Why doesn't this function?
Please support this function.
Hi @sooseok.sim1,
Sorry for the trouble with this, we still need to add these features to Logic MSO. It’s on the list.
In the short term though, you can right-click a timing marker pair and select “zoom on pair” then export with the “visible screen” range selected. However the zoom feature will zoom out a touch past the pairs range, so the export file will contain a bit more data than that.
Please let us know if you have any other issues with your Logic MSO, and send us any feedback you have!
Thank you for your reply.
I knew this “zoom on pair” with the “visible screen” but this have some limitation.
I want to save the file size small. delete range method is possible for saving small file size.
I want to this feature at MSO.
have nice day.
