Hi, I’m using Logic 2.4.40 on Windows11 with MSO device. I’m trying to trim my captured data, but there’s no option in context menu when I right click. Am I missing something?
The original problem I’m trying to solve is that I captured SPI communication with logic channels and SPI analyser shows error because of some noise on clock when SPI is idle. I’d like to cut this part with the noise or make SPI analyser start decoding from marker / only in selected area.
.. it’s a known missing feature, planned for a future release.
I agree, it is a nice feature that I often use w/my logic before and miss having it with the MSO version. It is especially missed for trimming storage demands for save files, as MSO captures can use a lot more data than before. At least you can tune the sample frequency to help reduce file size, but I’d much rather have a larger initial snapshot that I can crop/trim afterwards vs. wasting time tweaking the trigger & buffer length for the right snapshot ‘pan & zoom’ ahead of time.
Meanwhile, have you tried adjusting the logic threshold to filter out the noise, or inspected the signal with analog channel? If only while ‘idle’ did you include chip select signal(s) to only decode when the SPI bus is active and a chip select is asserted?
Finally here’s, the full thread (quoted above), with work arounds for some other scenarios:
So it answers my main question: is it possible or not and why. It’s a little bit disappointing that I found out such things only after purchasing a device (manual mentions nothing about some functions unavailable with MSO).
I ended up tweaking my device under test to drive SPI lines before actual data transmit.
Thank you for the answer and I’ll be waiting for the missing features.
