While running Logic on Linux, it crashes when I plug in this USB-C adapter (DELL DA200): https://www.dell.com/support/home/en-uk/product-support/product/dell-universal-dongle-da200/overview
I activated the logs with export ELECTRON_ENABLE_LOGGING=true, but there is nothing useful in the log. The app just crash with this message:
@saleae/electron/main: renderer process died { reason: 'crashed', exitCode: 139 }
I doubt it can be useful, but here is the out put of dmesg when I plug the adapter:
dmesg output
[ 2700.109407] pci 0000:0f:00.0: [8086:15b6] type 00 class 0x0c0330
[ 2700.109483] pci 0000:0f:00.0: reg 0x10: [mem 0xd4100000-0xd410ffff]
[ 2700.109894] pci 0000:0f:00.0: enabling Extended Tags
[ 2700.110438] pci 0000:0f:00.0: supports D1 D2
[ 2700.110439] pci 0000:0f:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2700.110799] pci 0000:0f:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:07:01.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 2700.111123] pcieport 0000:0d:04.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 2700.111414] pci_bus 0000:07: Allocating resources
[ 2700.111512] pcieport 0000:07:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3e] add_size 200000 add_align 100000
[ 2700.111520] pcieport 0000:07:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 2700.111522] pcieport 0000:07:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 2700.111525] pcieport 0000:07:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 2700.111528] pcieport 0000:07:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 2700.111887] xhci_hcd 0000:0f:00.0: xHCI Host Controller
[ 2700.111893] xhci_hcd 0000:0f:00.0: new USB bus registered, assigned bus number 5
[ 2700.113228] xhci_hcd 0000:0f:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[ 2700.113948] xhci_hcd 0000:0f:00.0: xHCI Host Controller
[ 2700.113954] xhci_hcd 0000:0f:00.0: new USB bus registered, assigned bus number 6
[ 2700.113958] xhci_hcd 0000:0f:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2700.114025] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[ 2700.114030] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2700.114033] usb usb5: Product: xHCI Host Controller
[ 2700.114035] usb usb5: Manufacturer: Linux 6.2.0-26-generic xhci-hcd
[ 2700.114037] usb usb5: SerialNumber: 0000:0f:00.0
[ 2700.114271] hub 5-0:1.0: USB hub found
[ 2700.114295] hub 5-0:1.0: 2 ports detected
[ 2700.114510] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[ 2700.114514] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2700.114516] usb usb6: Product: xHCI Host Controller
[ 2700.114518] usb usb6: Manufacturer: Linux 6.2.0-26-generic xhci-hcd
[ 2700.114520] usb usb6: SerialNumber: 0000:0f:00.0
[ 2700.114686] hub 6-0:1.0: USB hub found
[ 2700.114709] hub 6-0:1.0: 2 ports detected
[ 2700.372367] usb 5-2: new high-speed USB device number 2 using xhci_hcd
[ 2700.617333] usb 5-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=49.66
[ 2700.617349] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2700.617357] usb 5-2: Product: USB2.0 Hub
[ 2700.617363] usb 5-2: Manufacturer: GenesysLogic
[ 2700.620756] hub 5-2:1.0: USB hub found
[ 2700.621288] hub 5-2:1.0: 4 ports detected
[ 2700.740737] usb 6-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 2700.764434] usb 6-2: New USB device found, idVendor=05e3, idProduct=0617, bcdDevice=49.66
[ 2700.764456] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2700.764467] usb 6-2: Product: USB3.0 Hub
[ 2700.764475] usb 6-2: Manufacturer: GenesysLogic
[ 2700.768547] hub 6-2:1.0: USB hub found
[ 2700.768956] hub 6-2:1.0: 4 ports detected
[ 2700.928324] usb 5-2.3: new full-speed USB device number 3 using xhci_hcd
[ 2701.032211] usb 5-2.3: config 1 has no interfaces?
[ 2701.034680] usb 5-2.3: New USB device found, idVendor=0835, idProduct=2a01, bcdDevice= 1.46
[ 2701.034696] usb 5-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2701.034704] usb 5-2.3: Product: BILLBOARD DEVICE
[ 2701.034710] usb 5-2.3: Manufacturer: BILLBOARD CLASS
[ 2701.034716] usb 5-2.3: SerialNumber: 1AC740000000000070993B3F00000000
[ 2701.108606] usb 6-2.4: new SuperSpeed USB device number 3 using xhci_hcd
[ 2701.129726] usb 6-2.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[ 2701.129743] usb 6-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2701.129751] usb 6-2.4: Product: USB 10/100/1000 LAN
[ 2701.129757] usb 6-2.4: Manufacturer: Realtek
[ 2701.129762] usb 6-2.4: SerialNumber: 000C80000000
[ 2701.225435] usb 6-2.4: reset SuperSpeed USB device number 3 using xhci_hcd
[ 2701.251466] r8152 6-2.4:1.0 (unnamed net_device) (uninitialized): Using pass-thru MAC addr 10:65:30:02:91:bf
[ 2701.278317] r8152 6-2.4:1.0: load rtl8153a-3 v2 02/07/20 successfully
[ 2701.309488] r8152 6-2.4:1.0 eth0: v1.12.13
