First, congrats on making the analyzer outputs much easier to read when zoomed out. Major enhancement.
first a request: Could you avoid truncating the analyzer result with “…” unless it is too long to fit into the bar? I have a lot of packets that are long enough to get truncated but that would fit on the bar if not for the truncation
And an easy improvement:
Could you make the default color of a new analyzer match the wire color?
Thanks for the reminder @P.Jaquiery! We’ll keep an eye on this feature request for now. Unfortunately, it’s not on the immediate roadmap to fix. I just pinged our team about this.
Could you post that idea to the link below? In your idea post, let us know how you’d like us to handle colors for multi-channel analyzers as well. For example, when adding a SPI analyzer, would you prefer 4 separate colors for each data channel (MOSI, MISO, CLK, EN)? We opted to keep the colors consistent for all analyzer data channels, hence keeping it separate from the wire colors. https://ideas.saleae.com/b/feature-requests/
Thanks @timreyes. The “nag” comment was somewhat tongue in cheek, but the “pain every day” comment is real. From the outside it seems like an easy fix and would make at least a couple of customers very happy. But I understand the need for focus and bang for buck.
It may be a bigger issue for me than many people because I run multiple async serial channels at 912600 Baud as diagnostic output. I also run a fairly chatty HLA looking at I2C transactions. Both generate bursts of several hundred characters and trying to read those through a 50 character window by scrolling the trace is a significant pain!
