@oktem Unfortunately, we don’t have a simple and fast way of decoding based on a truth table. This could be an awesome feature to eventually support from within the UI (i.e. output decoded text based on channel states).
Right now, the best solution we can propose is for you to develop a new LLA (low level analyzer) using our analyzer SDK below. You will need C++ experience to do so, and quite frankly, it’s a bit of an overkill solution given the simplicity of decoding that you need, but it would be possible.
One thing we’re thinking of adding in the future is the ability to generate a virtual channel based on MATH or a truth table.
I understand that would not exactly be the solution you are looking for, but it comes quite close, and in case we decide to implement it, the ability to apply a truth table to multiple channels while calculating a particular result might put us in a good position to implement a simple decoding scheme like you’ve shared.
As such, I went ahead and added a comment for you in the idea post above so we can remember your particular need for this feature to be implemented. I’ll also bring your idea up with our product team.
