I use Logic Pro 16 to check UART (tx/rx/cts/rts) on my device (board) and it works well. However, in one day, it shows the same signal on different channel but I connect in the same way as before. The same signal sometimes also appears on RTS.
I have tried to connect ground pins for each channel (tx/rx/cts/rts) but it shows the same signal on different channel and is still not OK. I have also tried to connect it to UART on different device (board), but it shows the same signal on different channel and it is not OK either. I also tried to connect with different wires and hooks, but it is still not OK.
I have no idea what’s going on. What could make this problem?
Saleae: Logic Pro 16
OS: Linux
Software Version: 2.4.13 (Logic-2.4.13-linux-x64.AppImage)
