Resetting the driver when connecting
I am using a huawei matebook e go device on windows arm. The arm version of the app has been installed correctly, and the device drivers are being installed. However, as soon as I open the app, I hear a device reconnecting sound, and the app displays an error message indicating a connection failure. In the device manager, there is an exclamation mark appearing. How can I resolve this issue?
I have found a solution to the problem. You need to run the program with the analyzer connected to the device. Once the program reports an error connecting to the analyzer, you need to go to the device manager. There, you will find the analyzer with an exclamation mark, right-click on it and select “disable device.” After about 5 seconds, right-click again and select “enable device.” With a 90% chance of getting the error again, repeat the process of disabling and enabling the device. With a 100% probability, the program successfully finds the analyzer and works normally the second time.
@comonomon Glad you were able to find a workaround! Sorry for the trouble with that… we’ll investigate this.
@comonomon,
If you can reproduce the issue, could you send me some more information? when you see the device with the exclamation mark in device manager, please double click the device and copy/paste us the message. in fact, take a screenshot of the whole device properties window for the device when it has this error and send it our way.
The issue we see most right now is that you have to manually install the driver a second time when it’s in this state. Please try updating the driver while it’s in the error state using the driver that comes with the software (C:\Program Files\Logic\Drivers). Usually after that the problem will be fixed for good, at least for that particular device type.
