Official Arm64 support for Windows and Linux
Hello!
We’ve just released Arm64 support for Logic 2 right now through our new insider build program.
You can learn more and download the release here: Saleae Logic 2 Insider Builds
I’d like to share some details about these newly supported platforms.
We hope you enjoy the releases!
Linux Arm64 Support Notes
We expect our Arm64 Linux build to run out of the box on Ubuntu 22.04+ and Raspberry Pi OS, and similar Linux distributions. Our build environment is based on Ubuntu 22.04 LTS. This is where our major dependencies come from (glibc, etc.)
If you run into dependency issues on your distro, let us know! We can try to adjust our build environment to improve compatibility.
Note on USB Power:
Logic Pro 16 draws about 600mA. If you’re using a Raspberry Pi or other USB powered device, either make sure your power supply has extra current to spare, or try using a powered USB 3.0 hub, to ensure your machine does not brown-out.
Reporting Issues
We have no known issues with the Arm64 Linux release at this time. If you encounter any issues, please let us know! You can reply to this post, or contact support. Please be sure to include:
  • Details of the error.
  • Your system hardware.
  • Which Saleae device(s) you’re using
  • What Linux distro you’re using, and version.
  • Output of uname -a.
  • Any additional steps required to get the software to run, if any.
  • Does the software open?
  • Does the software detect devices?
  • Are you able to capture data?
Windows Arm64 Support Notes
We’ve tested the Arm64 Windows software on Snapdragon X and Snapdragon 8cx Gen 3 based Windows 11 computers.
Known Issue
We have a pretty serious known issue with USB 3.0 bandwidth and capture reliability. If you’re using a USB 3.0 analyzer, like Logic Pro 8, Logic Pro 16, or Logic MSO, recordings are currently limited to about 20% of the maximum throughput.
For example, instead of being able to record 500 MS/s digital on 6 channels (100% throughput) you will be limited to about 50 MS/s (10%) or 100 MS/s (20%) depending on the duration of the recording.
I haven’t had a chance to really dig into this yet, but initial testing suggests that this is an issue with the Qualcomm USB 3 host controller stack (driver or hardware). At these data rates, our devices are highly sensitive to tiny increases in USB request latency, due to limited device side buffer size. We’ll post as we have updates.
Reporting Issues
If you encounter any issues, please let us know! Also, if you notice that you’re able to record at 100% throughput (e.g. 6 digital channels at 500 MS/s) without issues, please let us know too.
  • The make and model of the computer you’re using.
We’ve asked most early Arm64 Windows testers to test this, and so far the issue has been reported on 100% of systems. All systems were Snapdragon X based.
Is there any plan to make this software run on Android (16)? I use a Tab S10 Ultra as a laptop replacement (when working while traveling), and it would be useful to run this on the tablet to debug devices in the field without needing my computer.
Hi @josevitor867, thanks asking. I’ve just did some initial research on the idea, and actually porting our application to Android would be a pretty insane project, since so much of our stack would need heavy modification to run there.
That said, I am curious about two potential paths forward. I don’t have an android tablet to test these, so if you give either a try with our arm64 Linux software, let us know!
Android’s integrated terminal:
Termux app:
Termux X11 add-on:
I don’t really expect either of these to work, but if you’re curious, I’d love to see your findings.
If you give it a try, please test out a number of commands:
# basic launch test, probably not going to work. output could be useful.
./Logic-2.4.45-insider.2-linux-arm64.AppImage
# this will extract the app image to ./squashfs-root/
./Logic-2.4.45-insider.2-linux-arm64.AppImage --appimage-extract
cd squashfs-root/usr/lib/logic
# print out linked libraries. useful for finding missing dependencies.
ldd Logic.bin
ldd resources/linux-arm64/libgraph_server_shared.so
lastly, try running the Logic.bin binary directly:
./Logic.bin --no-sandbox
I don’t know what to expect, but it would be cool to find out! Please let me know if you give this a try.
By the way, even if this were to somehow work, it’s pretty unlikely that our USB device would actually be visible to the application.
