Logic 2.4.45
2.4.45 Download Links
2.4.45
Welcome to the 2.4.45 release of Logic 2! There are a lot of changes in here! Many of these were released earlier as part of our new insider release channel. Feel free to check it out!
As always, feedback is very welcome!
What’s New
  • Added support for Arm64 Windows and Arm64 Linux. (note, arm64 Windows has a known issue with high sample rates with USB 3.0)
  • Added experimental feature for Raspberry Pi OS support
  • The analyzer data table now has an expand button which will make the data table full height.
  • Improved session save speed by ~4x, improved load speed ~2x.
  • Corrected numerous capitalization and grammar issues in notifications and other areas.
  • Moved MSO PC-side memory buffer to the recording settings sidebar.
  • Save and load error messages are now more specific.
  • Improved export dialog for Logic Analyzer devices.
  • Improved the sample rate change system when encountering a capture read timeout with logic analyzer devices.
  • Upgraded to Electron 41.
  • Improved error messages returned by the automation API when working with analyzer settings.
  • Sidebar accordions now remember if they are opened or closed.
  • Fix issue where in rare cases where logic analyzer captures using a digital trigger could bypass the session memory limit
  • Fixed issue when selecting the last session tab while tabs were scrolled.
  • Arm64 Windows installer now properly installs device drivers.
  • Fixed MCP schema $ref names.
  • Fixed issue where navigating to a specific time point with logic analyzer devices in trigger mode would navigate to the wrong time point.
  • Fixed missing hardware revision in device info dialog.
  • Fixed issue where the application did not clean up temporary files if a file load operation failed.
  • Fixed rare crash during specific trim operations.
