Logic 2.4.45 Insider 2
Download Logic 2.4.45 Insider 2
Unlike the regular release links, you can always download the latest insider build here:
If you already have the last insider build installed, you should get notified about the update too.
This is the second insider release! We’ve been very busy since the last one, mostly with architecture and build system improvements that serve as the foundation for upcoming work. However, this release is still packed with a long tail of medium and small improvements!
Also, this release came out a lot later than we hoped. To help increase cadence, we’ve just replaced our release process with one that’s much lower overhead, to make it as easy as possible on ourselves to ship releases more frequently.
We’ve also streamlined the process of getting small bug fixes and feature improvements added as they come in through support.
Feedback welcome!
  • The analyzer data table now has an expand button which will make the data table full height.
  • Improved session save speed by ~4x, improved load speed ~2x.
  • Corrected numerous capitalization and grammar issues in notifications and other areas.
  • Moved MSO PC-side memory buffer to the recording settings sidebar.
  • Save and load error messages are now more specific.
  • Improved the sample rate change system when encountering a capture read timeout with logic analyzer devices.
  • Upgraded to Electron 41.
  • Improved error messages returned by the automation API when working with analyzer settings.
  • Sidebar accordions now remember if they are opened or closed.
  • Arm64 Windows installer now properly installs device drivers.
  • Fixed MCP schema $ref names. (which caused issues with recent versions of Codex)
  • Fixed issue where navigating to a specific time point with logic analyzer devices in trigger mode would navigate to the wrong time point.
  • Fixed missing hardware revision in device info dialog.
  • Fixed rare crash during specific trim operations.
Known Issues:
  • We still haven’t fixed the USB data rate issue on arm64 Windows with Logic Pro 8 and Logic Pro 16, sorry!
Maximize data table:
