Install for RaspberryPI 5?
Wondering if there are any installs that can run on the new RaspberryPI 5? Running 64 bit?
So far feels like a great upgrade from the RPI4s and before. I am playing with one with
NVMe 512gb SSD and works well so far for secondary development machine.
That is, on it, I now have the normal stuff, plus:
Arduino IDE: both 1.8.19 and I built 2.3.3, including boards GIGA and Teensy
Arduino_CLI
SublimeText
VisualStudio Code, with Arduino plugin.
OpenMV IDE.
Now mainly just missing the Logic Analyzer.
Thanks
Kurt
@KurtE I’ve been meaning to snag one for myself. The CPU performance upgrade in particular is quite large (in addition to other benefits).
At the moment however, we unfortunately don’t have an ARM build of our software. There’s been an uptick in requests for this as of recent, mostly coming from RPi users and users of Microsoft’s ARM-based Windows laptops.
I’ll go ahead and post a comment on your behalf so we can track your need for this as well below (we’re tracking all requests for ARM support here).
Tim!
Can we have something like this:
  • server running on a Raspberry Pi with a Saleae analyser attached on USB
  • Logic2 is running on a PC (as a client) gathering data via LAN from the Raspberry server
In such way we can have a more portable analyser without sacrifising bigger displays and better views.
What do you think, is this something feasible?
@danergo Interesting use case! The limitation here would still be the same I believe (i.e. the Logic hardware would still need to be natively supported on Raspberry Pi, accompanied by ARM-based software to facilitate data captures). Sending data over LAN could be an external tool that would also run on Raspberry Pi.
This use case falls in line with the feature request post I shared above. This isn’t planned on our internal roadmap just yet, but I’ve gone ahead and added a comment for you so we can record your use case.
I’ve been using a original saleae logic 8ch analyzer with PulseView software on a Raspi 5 and everything works very well.
When you say you’re using RPi5 w/ PulseView and the original Logic 8 is that using an API?
We have a internal build of the Logic 2 software that supports arm64 Linux! It has a number of limitations, but if you would be willing to give it a try and send us some test results, we would appreciate it!
Please write in to our support email requesting arm64 Linux support, and we’ll send you the software and details. https://contact.saleae.com/hc/en-us/requests/new
Hello everyone! We’ve released official Arm64 support for Linux!
We setup a new release channel for insider builds, and the first release is for Arm64 support. I expect Arm64 support will be in the next stable release as well.
Insider program, complete with download links:
Details on Arm64 support:
Feedback appreciated! I’ll try to get this sent out over email to everyone who wrote in earlier asking for builds.
