Hi guys,
I have a problem with the Manchester decoder.
Added an image.
Does anyone know why nothing is decoded? tried with different dates.
Thanks
@info2 The bitrate might not be configured properly for the Manchester analyzer. Can you share your .sal capture file with me?
You might also try checking the bitrate by hovering over the fastest transitions in your data (which looks to be the full cycle on the right side of your transmitted data). Here is an example below, which determined the bit rate to be 10k bits/s (i.e. 10kHZ shown in the image below)
