Often, when I close Logic 2, the labels on the signals get lost, and revert to the default channel x values. Should these be saved on change, or do I need to take specific action?
@Glenn - Thanks for reporting this to us, and sorry for the trouble this is causing. This is not the intended behavior. The channel name settings should persist.
We haven’t had luck with reproducing the error though. Would you mind sharing the exact steps you take the reproduce the issue? Also, is it reproducible 100% of the time?
Had you sampled data after changing the labels? I find that if I change channel labels then close Logic2 without sampling the changes are lost.
This is on Windows, but it’s pretty likely the same on Mac.
This is quite strange. Other users are reporting the same issue, though we still haven’t been able to reproduce it on our end. We’ll run more tests.
In the meantime, I’d like to share how we’ve been going about attempting to reproduce this. You can find our attempt process in the video below:
Let me know if you find any differences with how you are causing the issue to come up! Also, let me know if you are able to test the same process as we share in the video to see if that also causes the issue to come up.
@Glenn We finally have a release of Logic 2 that may have solved the issue with channel labels getting lost. Would you mind testing it out and letting us know if that solves it? https://www.saleae.com/downloads/
