@jonas.aberg It looks like we have similar performance CPUs. I’ll try out the top command on my Ubuntu 26.04 LTS machine (it’s a fresh installation) to see what CPU usage I am getting at idle.
Our offices are closed tomorrow for a company holiday, but I’ll report back on my findings early next week.
Using Fedora latest, 13th gen I7 laptop, running Logic without anything connected shows about 40-50% of one core. I have 24 threads (I think 8 performance cores which are hyperthreaded and 8 economy cores which arent) so this equates to around 3-4% total CPU usage. My guess is that it more or less uses most of one thread so if you have a CPU with 12 total threads/cores you’d see more CPU usage than me but probably not actually more usage, if that makes sense. It does seem to be a smidgen power hungry when idling.
Just to add a data point: I don’t see the same behavior on my Debian 12 system with 8 logical cores, starting Logic 2.4.46 with no device attached, then capturing a few seconds of data with the demo device. The process hovers at 3.5% usage of a single core. I am, however, using a rather-less-common (I suspect) setup of LXDE viewed remotely via x2go. Your mileage will probably vary.
Also, allow me to recommend atop for a much-more detailed view of what’s going on with resource usage.
