First of all I use Logic 2 with the Logic2-automation python package for testing at my job, and It’s generally great to work with, so kudos and thank you for a good tool!
At my job we have a collective test repository using uv for version management. Somehow whenever grpcio releases a new version of their python module, we see an error coming from the logic2-automation when building the virtual environment or importing the package when running a test.
This causes noise as users(there are many) of our test repository are forced to perform a random .lock file update to get their tests to work whenever grpcio releases a new package, even though no changes has been made to the dependencies .toml or .lock file. Maybe you are familiar with this kind of issue?
I tried creating a small demo uv repository with only logic2-automation and I’ve noticed that the file .venv\Lib\site-packages\saleae\grpc\saleae_pb2_grpc.py is not always updating when a new .lock file has been made. even if the .venv folder gets deleted and recreated with uv sync. That could be critical as it contains a demand for a specific grpcio version. I can generate the error this way but I don’t know if this is the root cause of it all.
@aschulz Thanks for reaching out! I’m personally not familiar with this issue / use case, however, I’ll get this on the backlog for our software team to review.
Thank you! I will just add my thought to this that i find it a bit curious that Logic2-automation can ask specifically for a grpcio package version that is only days old, when the Logic2-automation package itself is a year and a half old.
I don’t know enough about average python package management to have a critical opinion whether that’s normal or not, but it does seem to me something that would make users attempt at overall package version control a difficult task.
Is this the error that asks you to –force-reinstall? Are these major / backwards-incompatible grpcio updates? I have no idea why it would be trying to auto update, this is the first time I’ve heard of this happening. If you can share your minimal repro that would be helpful.
We do have general issues around matching grpcio/protobuf versions. I’m spending some time looking into solutions right now.
If you are unfamiliar with uv repositories, my repo has a main.py file you can run using uv run main.py from the uv-demo folder.
You can specify project dependencies in the pyproject.toml file. If a package is written with no version specified, it will use the newest. When you run command: uv lock --upgrade the exact package dependencies and sub-dependencies will be resolved, based on the pyproject.toml file, and written into the uv.lock file.
With a uv.lock file you can build the virtual environment with the command: uv sync which creates/updates the .venv folder.
The problem is that the file .venv\Lib\site-packages\saleae\grpc\saleae_pb2_grpc.py does not entirely seem to update based on what the uv.lock file dictates.
If the grpcio package that was build is specified to a version lower than .venv\Lib\site-packages\saleae\grpc\saleae_pb2_grpc.py line:8 it will throw the error.
If you download my repo, you should be able to reproduce the error by opening a console in the main folder and run: pip install uv (if you dont have uv installed)
Thanks for sending all that over! We were able to reproduce the issue.
Originally grpcio-tools was a runtime dependency of our package, which meant it was affected by any protobuf/grpcio dependencies a project might already have.
We later moved the grpcio-tools dependency from a runtime to a build-time dependency. From what we can tell, this change caused the dependency to no longer be affected by the runtime dependencies, causing it to always use the latest version of grpcio-tools.
Our plan is to make it a runtime dependency again, add tests for these various scenarios and upgrade paths, and add documentation for some of the edge cases users were seeing which led up to this change.
Anyway, that’s just some background. Any other thoughts or feedback would be appreciated.
We are still experiencing noise at work due to this dependency property so any updates on progress or expectations for when this will be fixed will be greatly appreciated
I am experiencing an extremely similar issue with trying to bring this package into a uv-managed repo. In my case, the latest version of protobuf used by the repo is also capped, and we do not run uv lock –-upgrade in order to maintain strict versioning. However, when pulling in the logic2-automation package into our repo for the first time using uv add logic2-automation, we see that the file .venv\Lib\site-packages\saleae\grpc\saleae_pb2_grpc.py is not generated with our strictly defined version of protobuf, but rather the latest version available, leading to the same error you have likely seen that prompt users for a reinstall.
Based on the comments above, it seems like the change to move grpcio-tools to be a build-time dependency is under way and should hopefully help alleviate this issue as well.
@aar@95johnb I had tried the change after my last message but was still seeing issues. I will be taking a look again today and will provide an update by EOD.
I moved the grpcio-tools dep back over to being a runtime dependency, but the version installed at build-time does not seem (afaict) to be affected by the runtime version, which means the compiled protobuf files are still using the latest protoc. So, there is no change in behavior from a user’s perspective.
There are other approaches to consider. Using an older version of grpcio-tools that is forwards compatible with the latest appears viable. I tested building with 1.50, then using the files with various versions of grpcio/protobuf at runtime and the results looked good. Once I published an RC, though, then tested from there, I started seeing import errors again.
That’s where I am at right now. I am done for the day, but I can spend a little more time on this on Thursday. I will post any new findings then.
After looking into this further, I think the simplest approach for us is to build with protobuf 3.20.0 which supports the latest runtime and will do so until at least 8.x.y ( Cross-Version Runtime Guarantee | Protocol Buffers Documentation ). We will also switch to a binary/wheel release instead of a source release.
We are testing with it now. No initial issues were observed, I will let you know how it goes over the next few days when the others in my company have also ran with it.
Another follow up. We have seen no issues since switching to the release candidate. Although we run python in a virtual environment with fixed versions of packages we used to see issues on some pcs when trying to update those packages. We have have had around 50-100 people running with this rc in our repo without issues for the last week.
Thanks @huffman for making the changes and following up on it. It is really appreciated.
