Logic 2.4.7 error on launch macOS 10.15.7
Getting an error from Logic 2.4.7 when launching on macOS 10.15.7 about a failure to load a custom analyzer, but it looks like the analyzer it’s failing to load is one of the built-in ones:
CleanShot 2023-05-24 at 19.44.00
I assume this is a bug due to C++ stdlib ABI changes between whatever OS this plugin was compiler for and the OS I am running it on, but open to other suggestions. Thanks!
Hi @iris,
Sorry for the trouble! This was an error on our end. We have a fix here that we will be rolling out to all analyzers, and then pushing out a new release:
The min osx target will be 10.14, so you shouldn’t have compatibility issues. I will post an update here once the release is available.
Ryan
@iris,
We have an internal build with the fixed analyzer. If you are using that analyzer and need the fix, please let me know and I can send you a copy. If not, the actual release will likely go out next week.
Ryan
