If you missed it, we recently released a new light theme. Learn more here. Feedback appreciated!
Also, if you missed it, we recently released an automation API for Logic 2. You can learn more at saleae.com/automation. Feedback appreciated!
We rolled back the terminal color inversion we released with the new theme. Note, now when switching themes, we don’t re-color existing terminal contents, but new terminal contents will use the correct colors.
We added a “Dual Edge” option to the Simple Parallel Analyzer clock setting.
We added an experimental environment variable override to specify longer terminal scrollback limits.
set SALEAE_SCROLLBACK_LIMIT=1000000for Windows. -
export SALEAE_SCROLLBACK_LIMIT=1000000for MacOS and Linux. -
We reduced the minimum duration for “Trim data after stopping” from 10ms to 1us.
We rolled back our Linux build environment to Ubuntu 18.04, to restore support for Ubuntu 18.04. (reduces glibc requirement).
Fixed a bug where pressing shift in some text fields caused the focus to be lost.
Fixed a bug in the JTAG analyzer when dealing with frames longer than 64 bits.
Fixed a theme related readability problem with the custom extension error message notification.
Improved our error handling for extension installation behind certain company firewalls.
