I downloaded the auto baud rate detection plugin but it is not clear to me how to use it. The only instructions are “drag the measurement over a channel with some traffic”. Should the auto baud rate detection show up somehow in the measurement panel? I drag from the measurement panel over the waveform display?
@dmcdonald I’m happy to help! First you’ll want to install the extension from the extensions panel to the right of the app.
Then you’ll want to hold the Shift key while dragging to draw a measurement box across your waveform.
More details on how to use measurements can be found below:
I hope this helps!
