HLA for Audio waveform please
would be super if we could plot data like an audio-waveform within a HLA
really missing the ability to take I2S to a visual form like you had in the old xmos development tools
this would obviously also suggest being able to listen back to it
related question:
  • is it possible to stream the captured i2s data via a socket on the same machine to say another python process that would pipe it to coeraudio/portaudio and such…!?
@janny-bb Thanks for the request. I added a comment for you in the idea post we are tracking for this feature below.
Having said that, we’re also tracking a separate feature request for providing the ability to implement custom export options like below.
You can export your I2S data after a capture is complete via exporting the analyzer results manually, or via using our Automation API. I’ve provided some links below.
https://saleae.github.io/logic2-automation/
As an alternative option, you could write to an external file from within a Python HLA that sits on top of the I2S analyzer. This is not something we’ve tested nor have examples to share, but some details of a potential implementation can be found below:
This TDM / I2S analyzer allows you to export the data as a .wav file:
Not exactly what you are asking for, but it does get you some of the way there.
