@giants92 Thanks for sharing those added details! Yes, it looks like your desired output format is possible. Here is a quick example of 5 rows of a csv export file (16 digital channels enabled).
0.000000000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0.000007584,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0
0.000015840,0,1,0,0,0,0,0,0,0,0,0,0,1,0,0,0
0.000025672,0,1,0,0,0,0,0,1,0,0,0,0,1,0,0,0
0.000025688,0,1,0,0,0,0,0,1,0,0,0,0,1,0,1,0
The first column is the timestamp, and anytime a change in state occurs on any of the input channels, a new row is generated with a new timestamp that corresponds to when the output change occurs.
I’ve provided instructions for exporting data in the support article below:
With this configuration, you can simultaneously capture data on 8 inputs and 8 outputs of the PAL16L8 and export that data in the format shown above.
