So I’m using getting started example in Getting Started — Saleae 1.0.6 documentation.
I set up my SPI analyzer and I’m seeing decoded data in user interface time graph as well as data table on the right as hex:
# Export analyzer data to a CSV file
analyzer_export_filepath = os.path.join(output_dir, 'spi_export.csv')
capture.export_data_table(
filepath=analyzer_export_filepath,
analyzers=[spi_analyzer]
I’m noticing that miso/mosi data is no longer hex but I think bytes (but csv only support strings)?
If I’m exporting the same analyzer using “Export Table” option in user interface I’m seeing the same table but miso/mosi signals are now formatted correctly as hex.
My questions are:
Can I use automation tool and export analyzer output to hex or any other easily readable format and get similar result as using user interface?
Is there a way to read miso/mosi (byte?) information from csv file using Python? I tried but was not able to
@baltaspopieriauslapa Sorry for the trouble with that! For the analyzers parameters, you can pass a DataTableExportConfiguration object which has a radix setting inside of it. It looks like it’s being exported as ASCII by default.
You can take a look at the example in the link below for specifyng HEXADECIMAL as the radix type.
