Hello!
I am attempting to automate some CAN based scenario tests.
This code snippet generates a csv without any data present (the data fields are empty):
can_analyzer_1 = capture.add_analyzer(
'CAN',
label=f'CAN1',
settings =
'CAN': 0,
'Bit Rate (Bits/s)': 125000
automation.DataTableExportConfiguration(can_analyzer_1, automation.RadixType.HEXADECIMAL)
. # Capture data
# Export CAN1 analyzer data to a CSV file
can1_analyzer_export_filepath = os.path.join(saleae_output_dir, 'can1_data_analyzer_sample.csv')
capture.export_data_table(
filepath=can1_analyzer_export_filepath,
analyzers=[can_analyzer_1],
iso8601_timestamp=True
print(f"{can1_analyzer_export_filepath = }")
However when doing the export data table feature manually (see: Exporting Data | Saleae Support) I manage to get the data available in the csv file.
After some investigation I noticed that the manual export produces better/more correct data (also using hex values instead of int).
Any ideas how to make the automatic export produce the same content?
