I’m looking at CAN bus traffic with a Logic Pro 8 and Logic 2.2.10 software.
The CAN data is properly decoded in the signal window, but nothing is shown in the decoded protocols window so I can’t export anything to .txt/.csv, which is what I really need to be able to do at the moment. Data is streamed to the terminal view for CAN but the format makes it not terribly useful. I tried using the Async Serial analyzer and it does show data in the decoded protocols results table and export works. Is this something I can fix or is it on the roadmap to fix for CAN?
Sorry about this! Pretty sure the problem is that we stubbed a few of the less commonly used functions in the C++ analyzer SDK, and forgot to go back and implement them once it was working. Unfortunately, I don’t have an ETA on when this will be fixed yet.
In lieu of a working export, I tried copy & paste of the terminal output to a file but the format isn’t obvious to me. For example, here is one packet:
Standard CAN Identifier: '145'Control Field: '8' bytesData Field Byte: '128'Data Field Byte: !Data Field Byte: '135'Data Field Byte: '233'Data Field Byte: '242'Data Field Byte: '0'Data Field Byte: '0'Data Field Byte: 9CRC value: '27674'ACK
Why is the last data byte not enclosed in quotes? Is this format documented anywhere?
If it’s a printable character it’s printing the actual ASCII character and not the decimal value which is what you’re seeing in single quotes. IMHO that’s a really dumb way to present data. I sure hope that’s not the default, I don’t remember. NEVER should data output be done like that. Either keep it ascii, keep it decimal, or keep it hex. Mixing them is a sure recipe for mix ups. For reference 9 is 0x39 in ascii. So, the actual value there is 57.
