Can't get Salae to take measurements
I’m using Ubuntu 22.04.3 LTS and did the installation procedures found here: Installation | Saleae Support
When starting the AppImage or the Logic binary, I get the following errors:
[5411:0712/110748.427548:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[5411:0712/110751.549199:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
After running the udev rules command, I was able to connect my Logic Pro 16, but when I try to start the capture, it gives me an error of “ReadTimeout”. I’ve tried the lowest rate possible, still the same error.
After the 2nd try, the Logic Pro 16 starts blinking red.
I’ve checked “ldd -v libgraph_server_shared.so” and I seem to have them all:
linux-vdso.so.1 (0x00007fffa4ffc000)
	libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x000070e446800000)
	libAnalyzer.so => /home/carlosestevao/squashfs-root/resources/linux-x64/./libAnalyzer.so (0x000070e449d2f000)
	libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x000070e449cf5000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x000070e449cf0000)
	libnsl.so.1 => /lib/x86_64-linux-gnu/libnsl.so.1 (0x000070e449cd4000)
	libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x000070e449ccd000)
	libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x000070e446bd6000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x000070e449cc8000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x000070e449cc3000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x000070e446aef000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x000070e446acf000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x000070e446400000)
	/lib64/ld-linux-x86-64.so.2 (0x000070e449dfb000)
	Version information:
	./libgraph_server_shared.so:
		libstdc++.so.6 (GLIBCXX_3.4) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.9) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.15) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.22) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.1) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.3) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.5) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.7) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.8) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.9) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.11) => /lib/x86_64-linux-gnu/libstdc++.so.6
		libcrypt.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libcrypt.so.1
		librt.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/librt.so.1
		libnsl.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libnsl.so.1
		libutil.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libutil.so.1
		libudev.so.1 (LIBUDEV_183) => /lib/x86_64-linux-gnu/libudev.so.1
		libpthread.so.0 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libpthread.so.0
		libpthread.so.0 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libpthread.so.0
		libpthread.so.0 (GLIBC_2.3.3) => /lib/x86_64-linux-gnu/libpthread.so.0
		libpthread.so.0 (GLIBC_2.12) => /lib/x86_64-linux-gnu/libpthread.so.0
		libdl.so.2 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libdl.so.2
		libm.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libm.so.6
		libm.so.6 (GLIBC_2.27) => /lib/x86_64-linux-gnu/libm.so.6
		libgcc_s.so.1 (GCC_3.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libgcc_s.so.1 (GCC_4.2.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libc.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3.3) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3.4) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.4) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.6) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.7) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.8) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.9) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.10) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.11) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.13) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.14) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.15) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.16) => /lib/x86_64-linux-gnu/libc.so.6
		ld-linux-x86-64.so.2 (GLIBC_2.3) => /lib64/ld-linux-x86-64.so.2
	/lib/x86_64-linux-gnu/libstdc++.so.6:
		libgcc_s.so.1 (GCC_3.4) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libgcc_s.so.1 (GCC_3.3) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libc.so.6 (GLIBC_2.33) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.25) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.18) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.32) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.17) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.34) => /lib/x86_64-linux-gnu/libc.so.6
	/home/carlosestevao/squashfs-root/resources/linux-x64/./libAnalyzer.so:
		libstdc++.so.6 (GLIBCXX_3.4.21) => /lib/x86_64-linux-gnu/libstdc++.so.6
	/lib/x86_64-linux-gnu/libcrypt.so.1:
	/lib/x86_64-linux-gnu/librt.so.1:
		libc.so.6 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/libnsl.so.1:
	/lib/x86_64-linux-gnu/libutil.so.1:
	/lib/x86_64-linux-gnu/libudev.so.1:
		libc.so.6 (GLIBC_2.28) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.30) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/libpthread.so.0:
	/lib/x86_64-linux-gnu/libdl.so.2:
	/lib/x86_64-linux-gnu/libm.so.6:
		ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /lib64/ld-linux-x86-64.so.2
	/lib/x86_64-linux-gnu/libgcc_s.so.1:
		libc.so.6 (GLIBC_2.35) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/libc.so.6:
		ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /lib64/ld-linux-x86-64.so.2
What am I doing wrong, and how can I make it work? Thanks!
@nanisoreintensifies Sorry for the trouble with that.
For the errors you are seeing below, can you confirm if the software is still able to startup successfully? Given that you are able to get to the point of attempting to start the capture, I’m assuming the software starts up as normal.
For the LED blinking issue, there is a chance your Logic Pro 16, or USB cable, could be faulty. We discuss this issue a bit in the support article below.
To help rule out that issue, can you test your Logic Pro 16 on another PC, and using another USB3 cable if you have access to one?
