Hi I’m new to automation. I was wondering if there is a way to analyze data as it is being captured. Currently, I have this code:
with manager.start_capture(
# add different trigger to stop capture
time.sleep(5)
capture.stop()
# Add analyzers to the capture
A1 = capture.add_analyzer('Async Serial', label=f'a1', settings={
'Input Channel': 4,
'Bit Rate (Bits/s)': 2000000,
'Bits per Frame': '8 Bits per Transfer (Standard)',
'Stop Bits': '1 Stop Bit (Standard)',
'Parity Bit': 'No Parity Bit (Standard)',
'Significant Bit': 'Least Significant Bit Sent First (Standard)',
'Signal inversion': 'Non Inverted (Standard)',
'Mode': 'Normal'
A2 = capture.add_analyzer('Async Serial', label=f'a2', settings={
'Input Channel': 5,
'Mode': 'Normal'
A3 = capture.add_analyzer('Async Serial', label=f'a3', settings={
'Input Channel': 6,
'Mode': 'Normal'
A4 = capture.add_analyzer('Async Serial', label=f'a4', settings={
'Input Channel': 7,
'Mode': 'Normal'
# rest of code
Here, the capture stops, then analyzes each channel individually, but I’m trying to analyze the data as it is being collected. When I put capture.stop() after adding each analyzer, the code gets stuck on the first analyzer and never stops unless I manually click the stop in the gui. After I click stop, then the rest of the analyzers analyze one by one. Is there a way around this so that all 4 analyzers are analyzing at the same time as the capture is happening?
Also this makes me worried with having to trigger the stop. Would that mean I have to have a empty while loop running until the trigger happens to stop the capture?
