I am trying to use ManualCaptureMode() and modify the sample code. However, the capture stops before calling stop(). Please find my code below. Anyone has the same issue? How to resolve it? Thanks!
from saleae import automation
import os
import os.path
from datetime import datetime
import time
class Logic2Operations:
def __init__(self) -> None:
self.application_path = "W:\\apps\\Logic\\Logic.exe"
self.capture = None
self.manager = None
def open_app_capture_data(self):
# open app with the Logic.exe location
with automation.Manager.launch(self.application_path) as self.manager:
print("Logic 2 is launching")
# connect with logic2 device, logic2 default port number is 10430
automation.Manager.connect(port=10430)
print(f"Logic 2 is connected with port=10430")
# set up device configuration
enabled_digital_channels=[0, 1, 2, 3],
digital_sample_rate=10_000_000,
digital_threshold_volts=3.3,
# set up capture configuration
# Looping mode in the software. Stop this capture with the stop() function
capture_mode = automation.ManualCaptureMode(),
# start capture
# need to change device id, this one is demo pro 16
try:
self.capture = self.manager.start_capture(
device_id='F4241',
device_configuration = device_configuration,
capture_configuration = capture_configuration)
except automation.DeviceError as e:
print(f"Error starting capture:{e}")
def stop_capture_close_app(self):
if self.capture:
# stop capturing
self.capture.stop()
# import SPI
spi_analyzer = self.capture.add_analyzer('SPI', label=f'Test Analyzer', settings={
'MISO': 0,
'Clock': 1,
'Enable': 2,
'Bits per Transfer': '8 Bits per Transfer (Standard)'
# Store output in a timestamped directory
output_dir = os.path.join(os.getcwd(), f'output-{datetime.now().strftime("%Y-%m-%d_%H-%M-%S")}')
os.makedirs(output_dir)
# Export analyzer data to a CSV file
analyzer_export_filepath = os.path.join(output_dir, 'spi_export.csv')
self.capture.export_data_table(
filepath=analyzer_export_filepath,
analyzers=[spi_analyzer]
# Export raw digital data to a CSV file
self.capture.export_raw_data_csv(directory=output_dir, digital_channels=[0, 1, 2, 3])
# Finally, save the capture to a file
capture_filepath = os.path.join(output_dir, 'example_capture.sal')
self.capture.save_capture(filepath=capture_filepath)
# close app
self.manager.close()
app = Logic2Operations()
app.open_app_capture_data()
print("waiting")
time.sleep(5)
app.stop_capture_close_app
