Hello, I am unable to see the analog signals on the software, but the decoded digital data is visible. What could be the issue ? I tried new patches as well as restarted the program multiple times.
@mstharunreddy Sorry about that! Do you happen to be running on Linux?
This was a recently reported issue, and we’ve provided a workaround in the link below:
Hope that solves the issue on your end as well!
Hello, Yehh I’m using linux. Unfortunately I couldn’t find the cache directory, i tried searching different locations. Can you help me ?
Hello @timreyes can you help me with this..
@mstharunreddy The workaround I linked was tested and confirmed on Ubuntu. Can I know what Linux distro you are using?
Also, have you tried running the command below?
rm -r ~/.config/Logic/GPUCache
In case that command doesn’t work, can you share its output?
