Have an “.logicdata” capture that opens only on the 1.2 logic version. It’s a long capture and I have to check the smallest width between two values, to calculate the bits/sec. Is there a built-in function that we will display statistical information?
The older Logic 1.x software has the ability to detect the smallest pulse (pos or neg) within a given range. You can click the “+” icon next to annotations anc click measurements. After you add the measurement range to your captured data, right click on it to select the measurement you want. See image below:
Is this the kind of feature you are looking for? Hope that helps!
Thanks, this is what I was looking for.
