Alpha 10
@rei_vilo glad to hear from you!
Did you manually specify C:\Program Files\Logic when you installed the older software? By default, the “classic” software should install in either C:\Program Files\Saleae Inc or C:\Program Files\Saleae LLC, depending on which version it is. I actually selected C:\Program Files\Logic for the alpha software so it would not conflict with the older software.
Unless you need to keep the original software in C:\Program Files\Logic, I would suggest removing it and re-installing it in the default directory.
You might not need to do anything too - I haven’t tested this yet, but I would not be surprised that if when you update the alpha software in the future, it may default to use the directory you manually specified the first time you installed the alpha.
The “classic” windows installer and the alpha windows installers use different installer IDs so that the two installs should not conflict with each other - you should be able to install & update them independently.
Let me know if you have any other problems with the Windows installer or any feedback. The alpha release here was not digitally signed due to an ongoing problem with our CI provider, but we should have that fixed month when Advanced Installer releases an update for us. I’ve recently gone through the process of configuring a new installer and now is a great time to make improvements.
  • Mark
