How do i change the viewing setting from this
toWe are able to view the whole signal byte wise in HEX on a different PC with the same hardware and software. I am unable to view it on my system. I am able to view this in bit-wise order in HEX.
to@yash.bhatnagar I’ll be happy to help! To start, can you help provide both capture files if possible? I’d like to take a closer look at the difference between both captures on my end to better determine what analyzer settings you should use. It’s quite difficult to tell using the images you’ve provided, but hopefully your provided capture files will help provide more visibility for me.
