I am trying to make my first I2C analyzer for a chip that I just got back (yeah, I am part of a team designing silicon). I am trying to teach Logic (2.4.10) about our specific packets.
I can get data and see the traffic, but I can’t tell if a byte was NAK’ed. According to this page, a “data” byte SHOULD have an ack boolean that should be false if a NAK was received.
The only problem is that the data field does not seem to exist.
My code looks like this…
elif frame.type == "address":
if frame.ack == true:
self.address = frame.data["address"][0]
The frame.type exists, why doesn’t frame.ack exist? for an I2C byte?
I gets better. I have determined that the address of an I2C transaction is only the seven-bit version. The 8th bit which indicates read or write is stripped out, and apparently NOT AVAILABLE!
From the docs:
But I get this error:
So both read and ack are missing…
I know that I must be doing something stupid. Here is the top of my Hla class:
from saleae.analyzers import HighLevelAnalyzer, AnalyzerFrame, StringSetting, NumberSetting, ChoicesSetting
Am I missing something?
@kevin.harrelson
Add a line to print or display “the frame” that you think you have?
The from saleae.analyzers import looks fine, but I’ll assume the missing spaces between the libs/mods to import is simply a cut n paste deal?
So you may wish to try this:
elif frame.type == “read” :
if frame.data[‘read’] == true
You will get the deal …
Thank you for the hint. I have it figured out.
Here is my very simplified and dumbed-down code to demonstrate how to get the data out (note to Saleae employees, put something like this in your docs)…
class Hla(HighLevelAnalyzer):
def __init__(self):
print("Test running.")
print("\nGot frame type of " + frame.type)
print("Address is " + str(frame.data['address']))
print("Ack is " + str(frame.data['ack']))
print("Read is " + str(frame.data['read']))
if frame.type == "data":
print("Data is " + str(frame.data['data']))
Maybe of interest: for this sort of thing I use dispatch tables
self.handlerDispatch = {
"start": self.HandleStart,
"address": self.HandleAddress,
"data": self.HandleData,
"stop": self.HandleStop,
if newFrame.type in self.handlerDispatch:
# Handle the I2C phase data
return self.handlerDispatch[newFrame.type](newFrame)
# We don't handle this I2C phase type!
return AnalyzerFrame \
'skipped', newFrame.start_time, newFrame.end_time,
{'skipped': '!' + newFrame.type}
@kevin.harrelson well done and nice going. It’s a great community supporting the many efforts with these analyzers. Am glad the hint helped.
Cheers
Billy
I like this implementation also @P.Jaquiery , excellent chime in my friend
