Is there any way to store data in the MLA between frames?
I’d like to be able to treat the first data byte of an I2C bus specially, and I do not mean the address byte. I use the first data byte to specify the context of later bytes and would like to use a lookup table to define what should be displayed instead of the numerical data itself. My first thought was to just use a bool and change it after it is first accessed, then set it again on the next address frame, but this variable seems to just get deleted after each frame.
# High Level Analyzer
# For more information and documentation, please go to https://support.saleae.com/extensions/high-level-analyzer-extensions
from saleae.analyzers import HighLevelAnalyzer, AnalyzerFrame, StringSetting, NumberSetting, ChoicesSetting
# High level analyzers must subclass the HighLevelAnalyzer class.
class Hla(HighLevelAnalyzer):
START = 0
# An optional list of types this analyzer produces, providing a way to customize the way frames are displayed in Logic 2.
result_types = {
'i2c-address': {
'format': '{{data.description}}'
'i2c-data': {
def __init__(self):
pass
if frame.type == 'address':
direction = 'Read' if frame.data['read'] else 'Write'
address = (frame.data['address'][0] << 1) | (1 if frame.data['read'] else 0)
ack = frame.data['ack']
START = 1
return AnalyzerFrame('i2c-address', frame.start_time, frame.end_time, {
'description': 'Setup {} to {} + {}'.format(direction, 'ALL' if (address == 0) else address, 'ACK' if ack else 'NAK')
elif frame.type == 'data':
data = frame.data['data'][0]
if START:
START = 0
if data == 126:
DataText = 'ADDR CHANGE'
elif data == 5:
DataText = 'G1'
elif data == 9:
DataText = 'G6'
elif data == 4:
DataText = 'G92'
elif data == 6:
DataText = 'M202'
elif data == 8:
DataText = 'M204'
elif data == 7:
DataText = 'M205'
return AnalyzerFrame('i2c-data', frame.start_time, frame.end_time, {'description': '{} + {}'.format(DataText, 'ACK' if ack else 'NAK')})
else:
return AnalyzerFrame('i2c-data', frame.start_time, frame.end_time, {'description': '0x{:02X} + {}'.format(data, 'ACK' if ack else 'NAK')})
