I’m using Logic 2 v2.4.40.
I want to trigger when a signal stops and stays high. It seems like this should be easy, but I can’t figure out how.
Suggestions?
Thanks,
-Rob
Suggestions?
Thanks,
-Rob
Given your trigger criteria:
See the existing idea (and vote for it) here:
… as well as a clever work around using using the software glitch filter.
TL;DR –
On the trigger source channel:
Note: see above link for more details on the work around, including the technical limitations.
Also, you might want two channels connected to same signal, to both: (1) trigger on idle high (or on idle low) and (2) see all the signal edges w/o a glitch filter.
