Special characters in analyzer frames
When I have certain characters, e. g. > (greater than), in the string to be visualized in an analyzer frame it will be printed as “>”
result_types = {
        'Data': {
            'format': '{{data.Info}}'
return AnalyzerFrame('Data', frame.start_time, frame.end_time, {'Info': 'Test -> Test'})
Is there a way to print those special characters?
Hi @Phunkafizer ,
Is the problem that the > an other characters are being transformed into something else? We use the handlebars template formatting engine, which by default will do this. I’ll make a note to look into changing the default behavior, but for now you should be able to use 3 braces instead of 2 to disable the escaping.
For instance:
result_types = {
        'Data': {
            'format': '{{{data.Info}}}'
Hope that helps!
Ryan
Works like a charm now, thank you very much!
