I need a SENT analyzer. I found one @ GitHub - melexis/SENTAnalyzer: SENT (SAE J2716) Analyzer for Saleae USB logic analyzer and built it, but loading failed with “Loaded library does not have required functions”. Since it’s already 5 years old, I figure it might have been written for Logic 1.x. Does anyone have made anything for Logic2? If no, how would I upgrade an analyzer written for 1.x to 2.x?
@mickeyl Hm… strange. I ran a basic install/load test and was able to get their SENT analyzer running and generating simulation data on Win10 (image below).
I installed their provided .dll file under Releases below.
Here is how I installed their custom analyzer.
Can you confirm if you followed the steps above?
Thank you. For some reason, the cmake process went havoc here. The SENT analyzer now loads and works correctly. Do you know whether it supports both IDLE levels?
@mickeyl You’re very welcome! I’m glad to hear their SENT analyzer is able to load on your end now. For your question regarding IDLE levels, since we did not develop the SENT analyzer solution, you’ll likely want to reach out to the original developer to see if it’s something they support / implemented.
